Tysonmatc2
I have a chance to get a 136" Kit with rear cooler, and 136" Camoplast 1.25" track. I was wondering if it is worth going to a 136" and any suggestions like changing gears or clutching while doing so.
A little late, but - you can run a 1.5 track without 8 tooth drivers.Coles_55 said:Do it! Its the best thing I did to mine! I wouldnt even run studs, go with 8T drivers and a 1.5" track and it will hook up just fine!
There is a set of 8" extroverts on the driveshaft for sale on ebay under mountain max for 150.00 that would work, but it looks like it would take a while for you to get them cause the seller is from Canada. Thats not a bad price though. I think I might have heard that mountain max's came with 8 inch drivers, don't quote me on that. But check with a couple of the guys on site here that are parting them out and you could ask them if they are. Those wouldn't be extroverts, just normal drivers.Tysonmatc2 said:So here is where I stand as of now.... I am going with the 136" kit provided by Viperking and he is helping me install it. The track is an 1.25" Camoplast and I was debating on weather or not to put studs in it, I have been told that if I were to do studs I will have to change the drivers down to an 8 tooth. Does anyone have any 8 tooth drivers for sale or where can I find some and how much $$ do they cost? I am hoping to get the tunnel ext. riveted no this weekend as well as make my 3" seat wedge and 2" bar risers installed. I plan on taking some photos of it and doing a working log if possible. Thanks!
