harness racer
spend all of my time fixing other peoples problems , c'ant fix my own!!!!
Built a new engine for my sled this year , and its probably the best one i have built (yet to be proven ) , i first took it out a couple of weeks ago and started working on the jetting 150/150/148 rich...clip 3/12.rich.. p37.5 pilots lean and it was running awsome pulled 115 short of 2000ft. 3 passes all the same .
So last Sat it started doing funky s***t... It would run 8300rpm @105mph all day long but if i pushed the throttle anymore it would just die off .... i mean die like instent water on a fire
On Sun , we went to the gun ,(never got to run) and it was starting to do it @ lower rpm , by the time i got to my driveway i could not go more than 5000rpm .. pulled the carb bowls off everything looked ok , pulled the reeds out (carbon fiber ) everything looked ok so i pulled the heads and everything looked ok . So i put everything back together and put a new rack of coils on and on the road i go asphalt and all ( im so pissed by now i d'ont give a s***t) and voila 8900rpm ... wtf.. where did all these rpm come from?
Monday morning i take her down to dump road add 2 grams to the tip and @8300 rpm ( a litlle to heavy) 117mph , im pretty happy right........
wrongggggggggggg
last night 50 mile ride and she would only run on the low needle circuit and wot ... in between that blawwwwwwwwwwwww
Is my crank out of phase ?
carbs needles screwed up?
cdi?
sorry guys i fell better now !!untill i get home after work that is and i got to look @ it again ...thank god for the beer store !!
vince
wrongggggggggggg
cdi?
vince
