Hi guys, I found this on the tech area. It's an old setup Turk wrote up..? (the top one).
He just sent me the bottom one and said to try it.
Question is- Is there anyone using either setup, and what would you guys recommend for my 99 SRX 700? I know you usually get the best results changing the helix.
Any input would help would be Great.- I'm trying not to spend the money on a clutch kit.
98-99 SRX700 Trail/lake
48/42 Helix, 89a-10 w/4.5g rivet in 1st hole and .8g in tip, 2-3 engagement shims, b-w-b primary spring, stock secondary spring.
I would run 00-02 srx clutching
8dn-20 weights with 4.5 gram rivets in both holes
w-w-w primary spring
stock secondary set up
the lower is a tried and true setup works great
WNYViper
Im running the lower setup, it is GREAT, I had a Bender clutch kit in mine before and it was alright, but the 8DN20 setup is a night and day difference...
i just did the 8dn-20 deal and it does work well
Do you loose top end? and what does it engage at?
WNYViper
Its all stock parts, mine engages at 3800... I've lost top end (hit about 100 on the speedo now), but I've also got a heavy 1.5" track, stock 98 gearing, long traveled front and rear, and 10,000 miles on my sled... I dont contribute the top end loss to the clutching at all
Clutching is all about Quicker engagement?
WNYViper
Gagt518 said:Clutching is all about Quicker engagement?
no, clutching is about loading the motor for max hp to the track
This sounds real good guys, do any of you know about what RPMs you cruse at with this mod? (stock is between 6 and 7 grand).
