n8sjh
I am putting a new motor in a 1994 vmax 600 and it has a arctic cat secondary clutch.  Looking for info on the offset that I need from the primary and the secondary?  I should have checked it before pulling the motor now that I think about it but its done.
Also the primary is a comet 108 exp instead of the yamaha clutch but should be the same? Thanks
780srxgeorge
i think its  +/- 15mm.the cnt 2 cnt mit be the same.a lot moor low end with that thing.
			n8sjh
Ok so went out and played with it today.  I do not have a offset tool so used a long straight edge against the clutch and calipered the front and back of the converter and got it within .010 american.  Is that close enough or try to get it closer?  After I get it aligned I can get the correct offset by shimming?
