lonevmax
I had a heat exchange protector fall off and got sucked up into the tunnel. It is lodged at the front of the track, before it hits the snow. I can only see the tip of it. Do I have to remove the track, OR, is there an easy way to reverse the track to get it out. I tried to reach in there, yeah right.
just drop the last 4 bolts off the skid that mounts to tunnel,leaving the front 2 bolts in.Then you can raise you sled up and let suspension/track drop down enough for you to get in there.Done that when one of my dollies flipped up over the track and got sucked in between track/tunnel.
Good luck,no need to drop the whole skid..hope not for your sake...
Lift track off ground, get a buddy to help pull track backwards (one on each side of track, or turn secondary by hand... like I said get a buddy may need four hands.......
lonevmax
Thanks for the suggestions, guys. It had passed the lip under the tunnel, backing up didn't help. I had to drop the track. Now I have to figure out what is wrong with my drill, and try to pop rivet it back in place.
