2 Wheel Kits
Coles_55
Eagle, WI
Just wondering what you guys are running? I am looking to run 2 8" rears in the center with no outer wheels.
Big wheel kit
All I did was cut new spacers in the inside for the axle and moved the original wheels inside. You have the shaft sticking out on the sides.
I am just asking why? Why would you not run the outside wheels? I see alot of sleds with this option, I just want to know why?
Why does not having outside wheels make sidehilling easier? Weight?? These wheels are not very heavy at all. I carry more weight ,pop and water in the storage area. I have added the 4th wheel kit to all sleds, even the old Phazer. Al
Sidehilling
I don't know exactly why its apparently easier to sidehill or the weight saving, got that from the Cat shop. Nearly all sleds have 3 rear wheels and to take the 2 outsides off you still need to add one between the rails so you end up with one wheel plus shorter shaft and spacers for weight saving only. Land on a rear corner off a jump and see what happens. Another topic does anyone really feel the difference using 8" rear wheels, I can't see it being a noticable gain in performance.
I just bought the smaller back axle and put the stock wheels in the middle. This is the only pic I have.
I run the 8 inch wheels to take up some track slack with an off-set axle. 144 skid and 151 track meant I only had to setback just over an inch. Keeps the front from steering heavy.
