Another Tart with a clutch question..
97srxXT
Michigan
Just wanted opinions on my current clutch set up:
sled is a 97 sx700
cpr tripples
v force reeds
one layer of head gasket peeled.
22-40 gearing
8DF-00 clutch weights w/ 4.5g inner and 4.5g outter
orange primary spring
51/43 helix
at 80
stock spring
i have the 97sx with hauck pipes,one layer off head gasket,trail porting,vforce reeds 89L weights, same helix. i had to change the rollers from 15mm to 14.5mm to get the rpm's up. now she pulls hard at 8800 from the time i pin it all the way up to top speed.
going from a larger roller diameter, to a smaller one, doesn't increase rpm's, it lowers them, due to more shift force created. maybe you meant to say that you went from 14.5mm rollers to 15mm rollers??
