fasttoys17
have couple photos attached. finally got the viper all put back together and in the process of trying to get it started. i have some extra wires. on the right side above the chain case i have two wires a black one and a redish colored one can not find where they go
on the left side near the relays in have a white connector with few wires going into it but no place to plug it in.
any ideas on where these go on my 02 viper would be some great help. having some trouble getting it fired up.
Cam/ Viper adict
Does your sled have electric start or reverse?? I will try to take a look at my sled tonight and check... My sled has the reverse and E-start..
fasttoys17
no reverse and no electric start
The 2 small wires are for the back up beeper, and I believe the big one would go to the starter if you had one
fasttoys17
well guess im kind of at a loss at the moment. i have fuel and spark but i cant for some dumb reason get this thing to fire up. WTF am i missing here?
super1c
Super Moderator
does it fire with a little premix in the cylinders?? How many times have you pulled? It just might need a while to prime the system. I know when you drain the fuel pump and carbs it can take a bit to get her going again.
Cam/ Viper adict
Looked at my sled and the wires on the chaincase side seem to go to my reverse for the back up alarm. The other I dont see but is it possible it goes to your servo for the power valves??
