sunken viper s
blue800
powers lake wi
buddy sank his 04 viper s today wont be pulled untill tomorrow
any thing besides the normal to look at (lcd gauge cluster,dcs,elec. speed pick up ect.) any help would be great
thank you for your help
Thats a shame. They never seem to run the same after they sink.
Put it on it's side pull the plugs and pull it over a bunch of times to get the water out. Also drain the gas and oil.
There was a lengthy post on this very subject last Winter.
Try search : "sunk my SRX need some help"
The seat will be the hardest item to dry out.
Yes, get the engine running add extra oil to gas, say 25-1 ratio verify oil pump is pumping. You need to get as much oil on the crank brgs as possible in the first start up. Some electrical items will have to be replaced also, but First get the engine running, and then fog it. You can get the chain case, seat, power valve motor, ect later. Try to keep in warm area. Now is the best time to remove and dispose of seat, try to locate a BOSS seat for replacement.
So what you guys are saying is that my SRX CANNOT float? Jeesh, all this time I figured if it can fly, it can swim lol... GOOD luck, want to borrow my shammie?
