vintagemuscle
ok, i've got an 02 viper, with slp triple pipes and carbon fibre reeds. ever since i bought it a few weeks back it has been giving me grief. one time it pulls like an animal out of the hole and then falls on it's face at 85mp/h feels like a bog. the next time it bogs at any thing past 1/4 throttle. i changed the cdi, cleaned the carbs, and adjusted the pv's with no improvement. also myfeul light, oil light, temp light, and engine light dont light up. help i'm gonna go insane. also been checking the main harness under the engine andhave only found 1` minor rub through
kirk700 srx
Check your stator for proper current
Might be your clutching is on the edge & it ain,t backshifting in the warm weather.
vintagemuscle
my headlights and handwarmers don't dim or lose power do you think it could still be astator problem? i'm gonna test it when i get to theshop tonite just to to be surekirk700 srx said:Check your stator for proper current
vintagemuscle
took it for a ride with with the hood and clutch cover on, seems to be shifting alrite. thanks, keep the ideas coming. i know it's gonna be something simple i'm missingTurk said:Might be your clutching is on the edge & it ain,t backshifting in the warm weather.
Waters88
Could you stator be loose? Maybe stator pick up loose? I had a bad bog issue, and it would run really weird, up until it quit one day, and wouldnt restart. Got down to the stator, and the pickup had fallen off.... just a though.
Have you checked for good strong, blue spark??
vintagemuscle
i'll pull off the recoil and check, my spark seems really good when you pull it overWaters88 said:Could you stator be loose? Maybe stator pick up loose? I had a bad bog issue, and it would run really weird, up until it quit one day, and wouldnt restart. Got down to the stator, and the pickup had fallen off.... just a though.
Waters88
Hmmmm.... i would think you would get weaker spark, but while you are there I think you should check your stator to see if its not going bad.
i think your clutch doesnt work properly... what u got in there
vintagemuscle
all stock, slp says thats all you need to run
modsrx said:i think your clutch doesnt work properly... what u got in there
well if u run slp i'm pretty sure its not stock clutching
vintagemuscle
slp's instructions for clutching say... 8ek 13.9/13.9,y-w-y primary spring,47* helix, red secondary spring, 70* preload. thats pretty much stock isn't it
your asking the wrong guy,all mod does is keep sticking his head out that window looking for snow and keeps catching the flu...lmao!!!!!!!!
hey blue i got the flu doctor give me a month off now ...........................
yeah they ask to run smaller rivits weird ..engine should make more hp than stock...
kirk700 srx
I think you got the I'M WAITING FOR SNOW FLU... Move to labrador ... We have 6 months of snow a year!! From November to May
modsrx said:hey blue i got the flu doctor give a month off now ...........................
is there gonna be enough snow Kirk for the annual Caine's Quest...don't know if I got that name right..wait a minute..it's the Mod's Quest...lollllll
kirk700 srx
There is always enough snow for "Mods Quest" Too much for the Old folks that always have the FLU though!
could be a first...at Mod's Quest!!!!! H1N1 Flu rider named modsrx is now in 5th place,he is trying to make a race of it...with boxes of tissues everywhere down the trail,he is confusing the competition.His eyes are glazed but he is making an attempt to pass the Arctic Cat that is in 4th spot....Stay tuned for further race results here on TY..back to you Kirk.....lollll
Kirk..what is his chances of passing the Cat..then the Poo and Doo after that.Who is in 1st place anyways...lollll Can't see for all the dust..I think it is the Bluemonster in his SRX.........
kirk700 srx
Its a close race...6th and 7th is pickin up speed, the snot and tissues is causing some concern for them ...
