chilli
Aside from different jetting in different years, ara the carbs usable in every year?
Aka will 2001 carbs work with my 99 for example?
98-99 doesnt have tps
Another carbuerator point, that was interesting, was posted by 9801srx under "why srx hard to start not vipers".:
-"9801srx" found that the choke fuel pickup and choke air bleed were different from the Viper carbs to the SRX carbs
IMO: if you change the brass pretty well all the TM33 carbs that have the carb heat feature are interchangeable...the TPS could also be an issue on the PTO carb.
chilli
ok, ill stick with 98/99s then
