cooling on viper
09nytro
Grayling,Michigan
I can't get any coolant out of the bleeder on top of head where the carb heater valve is . I lift the back up & got the air out with the rear bleeder i don't know y its not coming on head .
maybe the hole is plugged ?
maybe the carb heater valve is preventing coolant and or air from reachin gthe bleeder.
also, dumb question but, is the sled running when you crack the bleeder ?
I have an SRX not a Viper so I'm not all that familier.
sorry, my 2 cents. good luck.
I did it running & not running still nothing . maybe not the right thing to do but i put compressed air to it to see if it is pluged & it was bubbling at tank . Allso pulled carb heater hose off coming out of hose but not the head
thanks daman . it worked coolant coming out not very fast but it is . I all so pulled the carb hose off & rocked it & it started flowing then put the hose back on & started flowing out bleeder like i said not vary hard but flowing . I think i got it wife will be happy she can ride ( doesn't like riding the polaris )
