yamyrider
is there any difference between the needles in an srx 600 versus srx700.the part numbers are different
yamyrider said:ok...so whats the difference....Q4...Q6????
spoons said:think you just answered your own question
valin said:The letters in the needle description depict the different tapers on the needle, and it will affect how the fuel is drawn during partial throttle application.
F = 1 degree, 30'
N = 3 degrees, 30'
G = 1 degree, 45'
M = 3 degrees, 15'
Generally, there is a number after the ones you have given that states the top width of the needle. I am assuming the numbers you have posted after the letters either have to do with needle length, or where those tapers begin on the needle. The changes on those two needles are minimal, and providing they run the same length, you won't notice much of a difference.
