back again with my srx 700 secondary clutch
hessracing
Iron Mountain Michigan
hey guys i rode around this weekend with the clutch on the 9-2 setting that hauck reccomended, it does not pull no where near as hard as it did before it feels like more mid range to topend and it use pull out of the hole alot harder it was on the 6 but I cant remember what the inside setting was on I din't even know that there were settings on the inside till the spring broke and i cleaned it all up the 1 2 and the 3 and it seemed to pull alot harder any help guys?? the primary clutch is stock!
The tighter the wrap(what you had originally)the better the back shift for corner to corner, the looser the wrap better top end,lake racing,etc.
try 80 deg like tony mentioned,that would be 6 on helix and 2 on clutch.
