Quick question on oil consumption
TeamHard24
Osceola, WI
Was reading through thread of the 04 Viper using oil.
What are Vipers usually set up for stock on oil consumption ratio
And what should they be set up for so they don't blow? And how?
if daman is out there he had a really good post on "high consumption on 00' vmax 700" on how to do it.
pretty sure ur answer will be 50:1, or one ounce for one thank of fuel i think.
Yamaha just recommends a cable setting in mm via service manual,as far as a specific ratio info there is none. but from my research on adjusting pumps getting them dialed in to Yamaha's gapped spec range is an average of 50:1.this is a good all around usage that seems to be right,not to rich not to lean.
