have msrx mountain 1998 with 136''
I need advice to go with the 144'' x 2''
have 9 tooth sprocket ...need 8?
rail extension?
I dont sure if I understand well mountain performancce kit or hartmaninc kit
tanks
rail extension?
tanks
yes you need 8T drivers for 2" track. also need rail extensions and a larger tunnel extension.
this kit is good or not....http://www.mountainperformance.com/kit1.htm
I am little afraid by Suspension Relocation
I did suspension relocation on my MM700 today, it was intimidating at first but it went pretty easy.
suva57 said:I did suspension relocation on my MM700 today, it was intimidating at first but it went pretty easy.
it's looking good for two rear shock or is hard on it?
As far as I know it won't hurt the shocks. If anything I think it would be easier on them.
suva57 said:As far as I know it won't hurt the shocks. If anything I think it would be easier on them.
which kit you use?
I didn't use a kit, I work at a fab shop so I was able to build my own parts. It turned out a lot like the MPI kit.
ok I look for buy mpi kit I wish is good choice
dont waste your time with mpi, they arent handling much for the 2 stroke sleds anymore. try hartmaninc.MSRX700 said:ok I look for buy mpi kit I wish is good choice
YooperMike
Second on the Harman Inc. Tom Hartman will set you up right!
If your interested I have an extra set of 8T drivers....
I have rail ext for 136 to 144 they are new, I nstalled them to find out they were the wrong ones, and removed them. $70 plus shipping
srxhair
try finding a used 144 doo suspension i put in a 151 doo skid that was the same tunnel width and 20 pounds lighter than my srx 121 skid
