clutch question and glad to be a member
clutch
I was kind of thinking along the same lines , ecspecially since I haven'yt gotten any response on how to tune it . P-85 , can you elaborate on this clutch and I think I seen some Yammi clutches on Hartman web sight also . I'm a little leary of the crank issue . I don't have a dealer within a reasonable distance so I will try to get this clutch off and check the run out . I want to determine if this is good before I stuff alot of cash in this sled . I bought it for 750.00 so I'm not feeling to bad . It needs about 1000.00 to make it right with some simple mods and new ski's , if the crank turns out good I will also do the MPI 151 kit . I sure appreciate all the info everyone has offered . Been a big help already . ;)!
