Bufbradwll
Does anybody know if you can install a new set of Apex handlebars on a 01 SRX? I am looking for a set of bars that are already hooked. Will the grip warmers work in the SRX? Any info would be awsome.
Yes they will bolt on. You will need to change the connectors and wire the grips in parallel to get any heat.
TeamHard24
Whats a good price for a set. Say just the bars and nothing else with it
Bufbradwll
Not sure, I am looking for a complete set myself.
MySX700R
I have seen them for sale on the 4 stroke side. Guys are switching to 06 handlebars on 07 and newer sleds to get better hand warmers (which are a problem for many without adding an expensive Yamaheater).
My 07 Attak hooked handlebars will work great one day and suck the next. I got 65 miles from my cabin and almost got frostbit, which made for a long drive back.
livewire_101proof
yes, bolt right up, connectors for warmers are diffrent, and have to be wired in series. also need a 2 inch riser just to get to stock height cause the bars are alot lower. i used a 3 inch and still didnt need line extenders or anything, gave it a nice feel.
TeamHard24
so would 75 for just the bars sound reasonable?
gbic1
I just gave a set away to a friend. What do you use for controls? Dont the sx controls slide off the end of the handle?
You will run in to trouble trying to install the throttle. The newer machines use a 2 piece throttle block. I had the same problem on my viper trying to install a 1 piece race bar. In the end I cut the one hook off and installed an aftermarket hook after I installed the throttle.
You can put the one piece throttle block on without cutting the 07 bars. It takes alot of hot water and patience. You will need atleast a 2 inch riser to get the bars to factory height .I went with a 2 inch pivot and a 3 inch adapter on mine works great.Just had to reroute the brake line. I have now gone to 06 grip heaters wired in parallel. Hands get HOT. Did not get that hot with the 07's.
I am sorry for the wrong advice. My bars are RSI race bars. I just assumed they would be the same issue as the Apex ones.
TeamHard24
So it is doable if I just get the bars nothing else and try to put everything on to them
livewire_101proof
i didnt cut my bars, 06 has replacable hooks, one allen screw takes em off, then 2 small rivets hold on the grip,drill them out and the grip slides right off, wasnt even that much glue on mine, came off pretty easy. they were 06 apex bars, got em off ebay with grips on em for $50.00, that was good though have seen em go closer to around $100 or more often.
crazy canuck
Was just wondering if wiring the '06 or '07 bars in series on a Viper would put any kind of extra load on the stator....aren't viper stators a little on the low output side to begin with?
The 06 Apex bars would be an easy fit. Just take off the hook slid the throttle block on. The grips are less ohms which would equal more heat.
gbic1
Yes that is what I was going to do. I did not think you could get them off with out ruining the heater. Gave them to a buddy to put on his 07 Apex so he could have warm hands.
Can i ask why people prefer the Apex bars over the stock srx or other bars on their sleds ?
eric.s.t said:Can i ask why people prefer the Apex bars over the stock srx or other bars on their sleds ?
Newer heaters because old heaters not working. Built in hooks
