Chain Case 2002 Viper ER
teamyammi
NY
Chain Case Problems... Help
I decided to takke mychain case cover off to inspect and when I put case back together I put the arm that is connected to the drive select just resting against the inside of the cover. When putting exhaust and battery back in I realized that the drive select will move all the way back in reverse but will not lock all the way forward. I put it on a jack to run the track and even thought the alarm reverse alarm sounded and the drive sleect was positioned all the way back where it should be track was spinning forward. Does anyone know how that arm should be positioned when putting the chain case cover back on? :o| :o| :o|
