Re Jet 2000 SXR 700
KEVIN
VIP Lifetime Member
OTTAWA
Need to re jet my SXR 700
Plugs very white
Carbs very clean
Must be because of the can
I am thinking about going to 150's
Anyone tried?
Stock jets now 145, 143.8 & 143.8
Just the can
But the plugs were scary white today
Has anyone re jetted after putting a can on their SXR 700
You should not have to rejet for just a can, check for an air leak in the carb boots or crank seal that might be causing it to lean out.
Ok I will check that out first
Will brake clean find it for me
