2000ft radar gearing?
Bullit01
Bonfield
Hey i was just wondering what gears guys are using in a 2000ft radar and what mph are you getting? hears the gears I have 22,23,24 on top and 38 and 40 in the bottom. I keep changing but I'm still not 100% sure of what gears I should be working with for the radars. any info would be great.
If it is a stocker the the factory 23-38 is probably fine . I beleive that is about 113 at 1:1 . A little overdrive and your right there.
has any one tryed going 24-38 gearing if yes did it work? Was the sled able to pull it? These are the other clutch parts I have. Weights I have 8dn-20
8bu-00 and 8bu-10. In helix's I have 53-47, 51-43,straight 47, straight 45,
51-40 and a 47-38 I think. So what do you guys think?
Hey yammiegod how much weight should I be putting in the in the 8bu-10 for that setup.
