snowhite
Should get an answer to this one,I was doing a ski alignment the other day on my Venture and doing some measuring and what the H,one side to center of the track is a lot more than the other! Sure, I'm taking line from the same points on the skis and measuring for my toe,I did the 2x4 trick along the track and also put a rod thru the ski posts for 0 (true) line.Measure each side and one side has about an inch and a qaurter wider stance! What gives here?At one time someone bent the control arm slightly,the tie rod tube is slightly out and the ski spindle took a twist,I sraightened the control arm, this still shouldn't put the stance out this much.A dealer told me the bulkhead might be out,nothing looks out or bent or missing,is this typical with a sled with 9,000 kms on her?
