Wire Rub..?????????????
Daggett
Crosslake
Website
www.weighttrainingworkouts.com
OK
1998 SRX 700 still wont run. Idles great but hit the gas and bogs down.
Tach works. Speedo not. Lights on and off.
Pulled the main wire harness and cant find any rub or nicks??? (see pic0
Should I be looking somewhere else?....down by the carbs and silencer?
Another problem?
check under the handle bar pad..thats where i had my problem..was doin the same thing...lights in out...bogging...shes all good now tho..
also look farther up the harness by the coolant hoses behind the brake caliper that is another bad spot
I am a skipping record on this topic... check wire harness above left footwell. I had em all chewed up where the harness does a 180 degree turn into the CDI box. Check all connectors use dialectic grease. Check wires under seat, dry if necessary, and I used shrink tube over this connector b/c water will pool and could create short.
I thought the 98 had a relay problem too sign was no head light. I could be wrong never owned one
voltage reg?
Have not found the problem yet.
No wires rubbed!
Polaris guy thought it might be the voltage regulator?
Is this a problem on the SRX?
Thought I would try the regulator next and then the Stator?
Any thoughts?
Is it normal for the lights to be off when you initially start a cold sled, and then turn on once it comes up to operating temp?
