PhatboyC
Ever since Yamaha widen their 8DN belt (apparently2-3 years ago) I have belt squeal. At fist when the belt is new it will squeal at idle. After some km on the belt it will rarely squeal at idle. But after a days ride it comes back I'm guessing when the clutch face plate is hot. As soon I let go of the gas going down hill or at a stop I hear some sort of squeal.
I measured my belt at 2mm high on the secondary. Manual says -0.5mm to 1.5mm. So I removed my secondary yesterday as per Daman instructions. Was looking to remove 3 washer from the bolts to get my belt a tad lower on the secondary. To my surprise I already have no washer between the bolts!? Is 2mm belt high way to much?
Re-installed secondary as is and before I put my belt back on I noticed some things. I can move my secondary on the shaft back and forth. Also I only have one #24 washer. I can move it with my fingers. At first I though I didn't tight the #27 bolt properly but no its in good.
Also is #16 supposed to come out when I removed the #27 bolt? I only had #25,#24,#26 when I removed the bolt. Didn't even notice #16.
