It's on my 03 Viper, the hand warmers are not working, but the thumb is. I checked connections inside the pad but its all good....
Where to start looking for it and how to do it...?
Thanks guys
NIck
Thanks guys
NIck
PNPerformance
Do you have the dual dial,s on that sled.? One that control,s the hand and other the thumb.
kirk700 srx
Unplug your handlebar warmers test each warmer for flow of current. I say one of your warmers are burnt out.Its usually only one at a time that burns out and it causes the other not to work either because they are in a closed circuit. Or you can hook them up individually to a 12 volt battery see which one is gone!
I will try the batery, but I have a dummy question...How do I hook it up....?
kirk700 srx
There are 2 wires on each warmer. positive to one negative to the other, leave it on there for a few min to see if they get warm if they dont get warm they are burnt out! I use a set of clips and a 12 guage wires even an old extension cord cut off on both ends will do!
