staggs65
I've done a handful and havent had a leak yet, knock on wood, got 3 to do right now. hopefully continue my lucky streak
well I got the old SRX started today and into the garage.Tore up the lawn a bit....
Got the exhaust and headers off and water pump cover.With a little patience I got the mechanical seal off and will install new one tomorrow.I hope this will solve my leak.Got to love that fogging oil,had a ton of smoke drifting here,lucky I don't live in the City and smoke out a neighbor or two.
lmao!!!
Got the exhaust and headers off and water pump cover.With a little patience I got the mechanical seal off and will install new one tomorrow.I hope this will solve my leak.Got to love that fogging oil,had a ton of smoke drifting here,lucky I don't live in the City and smoke out a neighbor or two.lmao!!!
well it has been awhile but finally got the SRX started today and the water pump leak is gone..go figure why a mechanical seal would of failed in such a short time after a re-build 2 years back.
I miss the sound of my triple can't wait till she's done
Hurry Up Eh!!!!!!
I had someone else do my water pump seals so hopefully they don't leak
start PRAYING Andy...
roudyroy1
is there any way to tell if its the rubber o ring or the machanical seal thats leaking?
I don't know if there is any way to tell without just replacing the o ring first and seeing if that resolves the problem. I did mine (oil, mech seal, o ring, etc) this past summer and it does not leak, but I had the same thoughts as you when I was doing the work. Would have saved A LOT of time. For what it's worth, I was able to do all my work with the engine in the sled. I think most guys pull the whole thing. Good luck!
