.losing power on. top end
srx98jj
lake milton , ohio
98 srx,..... can anyone help me? Just started doing this today. Around. 80 mph loses power and the temp light flashes.let out of throttle and it goes away. But run it up againg same thing.checked plugs all good everything seems ok? ???
the temp light is flashing because you could have a servo/power valve problem,get us a light flash sequence.
check servo operation,lower idle to 900 rpms does servo pull open valves nice and steady?
are valves clean AND adjusted properly?
tried to adjust power valves today, couldn't get valves to adjust properly not sure if the servo motor is opening all the way. Still has a blink code. Any suggestions? Anybody got a servo motor?
ok, daman and all the help ....this time i took it all apart myself. if ya want it done right , do it your self !!! onevalve pulled thru, other two missing the damn washer so i
they would never adjust anyway !! all better now ....i do my own work nowno matter how buisy i am !!!! thyanks totallyamaha people great sight !!
Good to hear,yup thats why NO ONE touches my stuff,they'll have to pry the wrench from my cold dead hands before I'd take my stuff in,lol
