Boost Bottle & Tors Clearance Problem anyone?
MountainMax
Churchill Falls,NL, Canada
Hey guys, I installed a Hauck (square) Boost bottle on my 2002 mmax and found the tors switch hit the bottle, I had to remove it and bypass it, Just wondering if anyone else had that problem??
Hey MountainMax....... I can't even keep my "Sunday best" shoes that clean..... " Mama get me some sunglasses, the glare is killing me ".....
I was just doing a little research on the bottles, mostly just to keep the airbox a little cleaner....Ha Ha...
Just a little concered in having to move the engine on it's mounts however....
Has anyone have any simpler solutions?..... Better start looking for one...
TJ
Yes, I know, I had reservations too, I found a fix, install a SRX steering colum will clear the carbs. I have a special one ordered with the bend in it and it's 2.5" higher so I can take out my spacer block too......
i had this problem on my 2001 srx. all i did was grind out a little notch for the tors to set in haven't had any trouble.
WOW MM that is one pertty looking engine you got there.
Very nice. :D
With all the mods you have done that machine must really fly.
Have you raced against any cats or doo's. :twisted:
If you have they must scratch there head wondering why you fly by them.
When I installed mine I used hard rubber pads under the posts for the air box. That kept the carbs from hitting the column and as for the tors I was able to tweak the wires up a touch and everything is all good.
