cylinder Question
renos2
Saskatchewan
what is the difference in cylinders with 8CH-01 and 8CH-00 there both of the readhead 700 non power valve just wondering if you can run both on same engine
one(00) looks like it's from a early 700 sx and the other from later 700sx,vm(01)i do think they would be the same and could be used but i cant say 100%
the 00 was '97 only. 01 was '98 & later. the only difference is the cylinder support boss cast ( external ) @ the intake side. the '98 & later is a stronger cylinder. porting & all other specs are the same. when you look @ both side by side the diff. is obvious.
there is no difference bt. a red sx or red vmx cyl.. they are all the same.
bob
