Turk's '97-98 sx600 clutch setup
yamadan
orangeville ontario
Picked up a 98 600xt and would like to set clutches up using Turk's setup. Questions: the 8ab usually runs on a 15.0mm roller and the xt has 8cr on 15.6mm rollers. Do I have to change the rollers? Also, no rivets were mentioned. Do I run the 8ab weights with no rivets?
Does anyone have a good setup other than Turk's recommendation? Tried to find some using the 'search' but everything is for the 600 triple.
this is a good set ive used,or check tech for members set ups look for vmaxjohn.
8ab weights,2.4 gram rivets in both holes
50/44 helix
green secondary spring at 60
you want 7800 on top
This is Turk's set up on the tech pages...
97-98 SX600 Trail
51/43 Helix, 8-ab weights , stock springs and gear up one tooth.
Have to wait til Tuesday for the weights. Going to try it with the 15.6mm rollers(stock on XT) first and see what happens. Will change the secondary spring from red(stock XT) to green(stock sx)
