early 175 watt ign systems fed the warmers right from the voltage regulator, the later 300 watt systems ran a seperate circuit from the cdi.
have you replaced this part yet? did it fix your problem.i have been having some similar issues on an 01 mtn max. ran tests on every item as per the service manual and found one item not to spec. its a coil located above the left foot well. it tested about 1500-2000 short of spec. i have yet to replace this, its next on the list. requires a special tester that reads in microferads?. i took mine to an electric motor rebuilder for testing. may be something to look at if it applies to your sled. i ran a troubleshooting test as per the manual and that was the only part not to spec.
