Can someone give me a quick explanation on how to adjust the powervalves. I have read many tutorials and write ups. I feel imbarrased for even asking this when i read so much on them. I understand that you take of the server cover. Start sled and lower in under 900rmp. mark the servo before or after this? Loosen cables before i take valves out or after? Usr 2 Allen keys roughly 2.5 - 3.00 stick them between the housing and the PV Casing. And then tighten cable till it starts to get tight? Thanks
Gagt518 said:Can someone give me a quick explanation on how to adjust the powervalves. I have read many tutorials and write ups. I feel imbarrased for even asking this when i read so much on them. I understand that you take of the server cover. Start sled and lower in under 900rmp. mark the servo before or after this? Loosen cables before i take valves out or after? Usr 2 Allen keys roughly 2.5 - 3.00 stick them between the housing and the PV Casing. And then tighten cable till it starts to get tight? Thanks![]()
Idle to 900 rpm if you don't have E/S. If you have E/S just cycle the key on.
Mark the servo motor. Loosen the cables. Loosen the two bolts on the P/V housing. Install two 2.5-3 mm allen wrenches.Check that servo motor has not moved. Tighten cables until the cover is snug on the allen wrenches. Lock the cables down and install the cover. GTG
Yamasquaw
- Jan 8, 2005
Just finished mine and i like to take off the y-pipe and feel them until flush.Takes more time but either way works i guess.
stein700sx said:Idle to 900 rpm if you don't have E/S. If you have E/S just cycle the key on.
Okay thanks man, Thats perfect
