I have a 2002 sx viper er and when I rev it to 6000 or above I have a lot of vibration in the handle bars. I believe this was due to a bad drive shaft bearing. I took it apart and the bearing on the clutch side has a little play but not a ton. I imagine when its turning that fast any little bit would be felt. Is this bearing the one that usually goes bad or the one on the chaincase side or do they wear equally?? Should I replace them both that I have it all torn down? Also the suspension on rear wheel on the clutch side would turn freely with the trackon when sitting on flat ground. Would that be caused by the worn bearig? Any comments from past experience would be greatly appericated!! Thanks Marv
