Just installed a Hauck big bore kit in my Viper. After having it melt down 3 times prior to doing this I was a bit nervous and installed three pyrometers. I was unsure about location and what max temp should be. I found some instructions online that stated the thermocouples should be 10-12" from pistons and temps should be 1000-1300 degrees.
My question is: Is this location correct, what should temps be, and should center cylinder run exactly 200 degrees hotter than the other two? I just put about 80 miles on it yesterday and at trail cruising speeds the two outside cylinders were running 1080-1150 and ceter was 1280-1350. Do I need to fatten up the ceter or all the cylinders?
Thanks in advance for any advice
