ikeever
- Sep 10, 2003
I bought these being told they would fit my 2001 sxr700. number on the box is "sts1hc 50-7 yamaha". came with a blue spring, and the directions are for a yamaha. but the blue spring is way too long, close to 2 inches longer than the stock one. the weights are 58.6 grams...anyone know if this is the right setup. i'm done some looking and haven't found a 50-7 setup for a yamaha. the weights look like they will fit, but the spring is making me wonder. no numbers stamped on the weight either. thanks
Those are old weights & probably for a comet/ac or polaris clutch. the heelclicker spring is usually about 4-5" longer then a stock yamaha spring. Those weights probably won,t work with out conversion pins & cutting off some material on the sliding primary shive.
HC springs are wicked long and makes putting the primary together a PITA.
