monstercman
I bot a use psi pipe for my 85 phazer
so what size main jet wood i need, just what size should I start with
I live at sea level
and need jetting/clutching specs for this set-up
does any one have the PSI spec sheets or the psi jet specs
I live at sea level
scroll down about four. where the red mad face is. thare is a link for rejetting a phazer with performance pipe...
big-kid said:scroll down about four. where the red mad face is. thare is a link for rejetting a phazer with performance pipe...
Scroll down where? I was looking for similar info
wkeggenhoff
phazer jetting
Years ago ran pi pipe. Was told 147.5's rAn for 2 weeks lean seized hole through piston. THen ran 150's. ran for 6 years pinned down lake WOT. Never a problem. We rode 1000ft level.
PINHEAD
What type of jets are in the carbs?Are they hex heads or round slot type mains?I have a aaean pipe that I want to use but I want to get the jets first before I take the carbs off as the sled runs great right now.
