snowmanhat
I trail ride in Pennsylvania at no great low temp or high altitude. Is it ok to use regular automotive antifreeze mixed 50/50 in my SX500R?
That's all I use in my SX600 and I ride in Central Vermont.
SX600abuser
I've always been told to run 60/40 mix. I always use that prestone antifreeze that is universal for all colors because it is formulated to not corrode aluminum. Just my 2cents.
grapeape
Silica free is what you need, and almost all current anti-freeze is.
snowmanhat
thanks for all the help guys
yup just fine,i use 50/50 mix.
horkn
grapeape said:Silica free is what you need, and almost all current anti-freeze is.
yep, hard to find stuff that isn't.
abumpa
I think I recall reading in my owners manual a 60/40 mix.
50/50 gives you a strong enough mix(-20),you don't need 60/40 you'll get worse cooling if you go with too strong of mix.
60/40 has been good for my sleds.mind you it does get cold out here to,so want the protection.
