unclearpine New member Joined Dec 11, 2005 Messages 7 Age 69 Location Uxbridge, Ontario, Canada Feb 17, 2010 #1 Will I be able to fit Apex skis on my SRX ?I can get a set cheep and I need new ones on the SRX
teamblue4 VIP Lifetime Member Joined Mar 19, 2006 Messages 118 Age 59 Location Roscoe, il Feb 17, 2010 #2 Yes, But it will make the front lower.
BETHEVIPER Life Member Joined May 2, 2003 Messages 2,725 Age 55 Location houlton, maine Feb 17, 2010 #3 flip the brackets left for right and upside down, grind a little on them and add a washer to the bottom bracket and you will end up back at the same level. dont forget to shim the skis properly after doing all this
unclearpine New member Joined Dec 11, 2005 Messages 7 Age 69 Location Uxbridge, Ontario, Canada Feb 17, 2010 #4 Are you talking about the shock top bracket? Do I have to change the rubber at the bottom of the spindle or can I use the SRX rubber piece?
