unclearpine
Will I be able to fit Apex skis on my SRX ?I can get a set cheep and I need new ones on the SRX
Yes, But it will make the front lower.
flip the brackets left for right and upside down, grind a little on them and add a washer to the bottom bracket and you will end up back at the same level.
dont forget to shim the skis properly after doing all this
unclearpine
Are you talking about the shock top bracket? Do I have to change the rubber at the bottom of the spindle or can I use the SRX rubber piece?
