worst
Worst meltdown I´ve ever seen. Did the crankcase and crankshaft survive? If so take apart everthing and clean it. I repaired a srx 700 a friend of mine owned after a small piston meltdown. I take it apart and found aluminium parts in crankcase bearings and even in the oil lines. Clean it so you don´t get aluminium from the oil pushed back into the bearings. My friends srx survived after this, but it was a lottery with the bearings, he didn´t have the money to change them. I would have done it but he had the sled for several seasons after this and run thousands of miles and we never seen any problems. Hope you can put it together without to much trouble, but it will be a lot of money to fix it.
staggs65
wow, i guess if youre going to do something, give it ur all
