98 SRX 700 Middle Power Value Leaking Oil
MobbsWR
Tahoe
I just noticed that my middle power value on my 98 SRX 700 was leaking a small amount of oil. I took the value out to clean and also noticed that it had pulled through. I was able to fix the pull through, but the oil leak still persists. Is this a big deal? I am thinking its probably a bad gasket. Would using some high temp silicone with the gasket until i replace it work? Thanks for the help guys!
