MikeSr
What is the horsepower of a 2000, SRX 700? And what is the cheapest way to up it?
tofastSRX
145 hp 2000-2002 1998 to 2000 138hp
madzx2
2000 srx 700 142hp @8400 rpm and tourqe is 91.7 @ 8000
staggs65
first make sure youre getting all the power to the ground with good clutching, then porting is the next best bang for buckAnd what is the cheapest way to up it?
madzx2
staggs65 said:first make sure youre getting all the power to the ground with good clutching, then porting is the next best bang for buck
x2 you need to be able to hook up. still struggling with that part myself but after tommorow i should have any problems.
Always more power....
Pauljones
what made the 2000-2002 have 7 more hp than the 98-99? jetting, porting, timing, something else?
They have different heads (slightly higher compression) and port timing plus a higher wattage magneto.Pauljones said:what made the 2000-2002 have 7 more hp than the 98-99? jetting, porting, timing, something else?
valin
MikeSr said:What is the horsepower of a 2000, SRX 700? And what is the cheapest way to up it?
Not enough.
staggs65
lol.. i've been waiting for thatvalin said:Not enough.![]()
mopar1rules
where are you located mikesr?
MikeSr
Racine, WI, just down the road from you.
journeyman
If I remember right AMSNOW dynoed the 2000 and newer SRX at 142 and the older 98-99 models were in the low/mid 130's.
mopar1rules
MikeSr said:Racine, WI, just down the road from you.
ok. well, you know you could just get the sled ported. one of the best bangs for the buck on a srx. i do srx porting too....
winterfunguy
How many HP can really be gained by porting...Who does trusted porting? My big brother has a 02' MXZX 800 with twin speedwerx pipes and good clutching, I want to beat him on the trail and the lakes but I'm in stock form right now besides 144 picks, a ripsaw, bender silencer and reed spacers.
mopar1rules
winterfunguy said:How many HP can really be gained by porting...Who does trusted porting? My big brother has a 02' MXZX 800 with twin speedwerx pipes and good clutching, I want to beat him on the trail and the lakes but I'm in stock form right now besides 144 picks, a ripsaw, bender silencer and reed spacers.
sent you a pm
