On/Off Switch in Engine?
MobbsWR
Tahoe
I have a 98 SRX 700. I opened the hood the other day and noticed for the first time that there is an on/off nob on the drivers left hand side of the machine near the carbs. I just bought this sled a few months ago and it has always been in the off position.
its to heat the carbs with the engine coolant
they say to only turn it on below a certain temp, i believe its 32F but ive always left mine off down to -20F
Thats to turn on your heated carbs. You don't really need them until it starts to get really cold out. But it is good to turn it on and off every once in a while or else it will sieze up and you won't be able to turn it.
ah. That makes sense. Yeah it never really gets that cold here. Most days it is between 20-50 f. This morning was an exception at 11f. Thanks for the info!
Some people also say to turn it on if you're playing in alot of powder. Me personally I always leave mine off.
Pauljones said:
mine is siezed in the off position, any ideas?
Wrap the knob in a thick rag and use a pair of pliers to open and close it a few times,if your lucky it will free up enough to turn by hand.Otherwise you may have to drain some of the coolant down below the water rail level where the knob is,take out the 2 allen head bolts,one on top and the other on bottom,pull the knob out and put some o ring lube on the rubber o ring and install it back into the rail.I've done this in the past to free up mine and it will help keep it free for a few years.
