I am posting this so others can learn from my mistake and stupidity.
While waiting for my cylinders to return from being ported I searched around for the parts that I would need to do the re-assembly. Just about fell over when the dealer told me how much the gasket set was. So I searched around on here for gaskets and other info. Found some posts of people re-using the steel gaskets and some that would not re-use the gaskets. I opted to re-use the gaskets. Why? Because we used to do this on our small block chevy's all the time and thot why would this be any different. Well 1200 miles into this season my coolant tank was pushing out coolant. Did some simple diagnostics and found that the head gasket was leaking it's compression into the coolant thus pushing the coolant out. I went to the dealer and bit the bullet and purchased a new gasket set. Getting everything cleaned up I grab the new gasket and think "why is it soo thick?" The previous owner had peeled two layers out and I just re-used what was there. Find out this is not good for my ported motor. I put the new proper gaskets in and go for a teat ride. Problem solved and believe or not but with the three layers of gasket in the throttle response and power is the same or better. I got lucky and did not damage the motor.
Moral of the story, ask lots of questions (even the stupid ones) and don't re-use old gaskets.
