mopar1rules
that would be crank/dyno peak. guys on here have tested stock tach to dyno tach and found them to be the same, so you can go off of stock tach.
Well if peak HP on the dyno is 8500 then we should be clutching to 8650 range (tach).mopar1rules said:that would be crank/dyno peak. guys on here have tested stock tach to dyno tach and found them to be the same, so you can go off of stock tach.
unchained said:Well if peak HP on the dyno is 8500 then we should be clutching to 8650 range (tach).
