well at these miles
comp test 140 psi all cly . leak down test is 10 %
i will replace the clutch rollers . i blew out the lower chain bearing landing off a jump . and put in two plastic washers it the pri clutch . other than that no failures , just maint .
i Will change other bearings so i dont have to worry about them
