hereismylife
I searched this,,,
I did read about the offset but I am doing this by hand because this tool is getting harder to find and I need to get this sled done to move on to the next one....
Anyhow I do read that it should be 15 mm offset from the back off the sheave to not sure where?
I am wondering also does the primary sheave stay the same front and back?
Should it be on an angle in the front of the primary and the back of the primary. Kinda looks tilted from front to back... When you rev the motor the motor will shift and the primary will be straight while going.
If it should be off from front to back what should the front be? the back is 15mm and the front is what?
thanks
Also here is what I am talking about......
http://www.totallyamaha.net/forums/showpost.php?p=425089&postcount=2
thanks
