bufalobob
new from bender. external secondary belt deflection adjuster & billet primary cover w/ bronze bushing. click on link below.
bob
http://www.benderracing.com/Belt_Deflection_Adjustment_System_BDS1_p/bds1.htm
bob
hereismylife
I did see that to but not sure how this will do anything. Anyone know?
bufalobob
belt adjuster lets you adjust belt height quickly w/o removing secondary.
stock primary cover has a fiber bushing. benders has bronze bushing. more durable & a lot less subjuct to failure. all are anodized aluminum.
bob
bob
hereismylife
Can you explain this? The only way to do this on a yama is with the 3 washers in the back. How would this tool help out? Does it bolt on the secondary somehow?
madzx2
i curently use i believe a max performance dflection adjuster but its getting a bit chewed up. i might have to pick up benders version. that clutch cover looks trick too.
For that price on the primary cover why no get one from Hi tech performance, it adjustable. Makes enagement smooth everytime. Maxdlx
madzx2
maxdlx said:For that price on the primary cover why no get one from Hi tech performance, it adjustable. Makes enagement smooth everytime. Maxdlx
you know the link to hi tech performance?
I have his number somewhere, don't know if his website is up. I'll get it for you
You need to talk to Duane
Hi Tech Performance
29024 650th Ave
Litchfield, MN 55355-4718
Phone: (320) 693-9289
I have one and can get a pic if you want
Hi Tech Performance
29024 650th Ave
madzx2
yea a pic would be nice. thanks for the info. how much does his cover cost?
hereismylife
I would love to know how this helps making things easier....?
edgeracer1
All i can say is i looked at the cover last week when i was out there and its nice and i will own one....Cant wait till they get the whole clutch built!
It allows you to adjust the secondary clutch from the front side without having to remove it. It is the same adjustment as removing or adding washers to the backside, just far more convinient.
I have on installed on an apex. It is from an unknown manufacturer (not Bender.) The issue I have with it is the play in the secondary is eliminated. The secondary is no longer able to float so perfect clutch alignment is crucial.
rx1jim
Can you post the website address for Hi Tech Perfomance?? A search on Hi Tech Performance produces a huge amount of companies with that name. Thanks!!
I think the site is down, was told making a new one. call the number i put up. I will get apic in he next few days of mine
