MikeSr
What is involved in changing out the tie rod ends that are connected to the radius rods? Do I need to pull the entire engine out, or what? Any special tools needed?
MikeSr said:What is involved in changing out the tie rod ends that are connected to the radius rods? Do I need to pull the entire engine out, or what? Any special tools needed?
sasksrx said:I don't know about anyone else but I had a hard time getting at the nuts for the bottom radius rods and holding them properly to loosen them under the hood. You can't get a box end on it. So I just tipped the sled on its side and loosened the lock nut where the radius rod turns into the swivel end and turned out the radius rod and left the swivel end bolted to the bulkhead for the righthand side one. But I was changing radius rods, not the swivel ends. I hope this isn't the one you have to change, its a real pain. I just pulled my pipes and left my manifolds in. It was a little awkward to get at but not too bad.
