01 mountain vrs 01 sxr trailing arm difference?
hereismylife
Pa
Website
www.hereismylife.com
I did search this and found that some arms are about the same. I found one that is off a 01 mountain sled.
I have a ( R ) Stamped on mine.......
Is the 01 sxr the same as the 01 mountain sled
The pics look close. The part numbers are different.
Anyone know?
01 mtn max has an "S" stamped on it. caster at 25.5*, shock bracket at 7*, radious rod angle 3*. an "R" stamp is shock angle 10*, caster and rad rod same as above. yes it will work as 3 degrees on the shock mount doesnt affect anything except a little more wiggle and umph when aligning the bolt. other than color, if applicable, bolt and go. just be sure to adjust ski toe and camber if you opt to run it, as you should do whenever you replace any front end components.
